Well this is interesting...
Old Jun 5, 2010 | 09:54 PM
Dirty Vegas's Avatar
Default Well this is interesting...
Something tells me my Nitrous Express Lightning solenoid shouldn't look like this...
It will not seal on the inlet side, and the purge port side. This is the results after using teflon paste. Frozen **** everywhere!
Old Jun 5, 2010 | 10:47 PM
custm2500's Avatar
Ph.D. in HUBRIS
oops!
Old Jun 5, 2010 | 10:57 PM
dnkynrbk's Avatar
dam man
Old Jun 6, 2010 | 11:01 AM
I never had to fight a solenoid this bad! No matter what I do, it has pin hole leaks in the same spots on the inlet and purge ports.
Old Jun 6, 2010 | 11:58 AM
MYSTIC-1SC's Avatar
damn. definetly has a leak.
Old Jun 6, 2010 | 12:34 PM
NOTFAST's Avatar
is it "mounted" via band clamp?
Old Jun 7, 2010 | 09:56 AM
Yup, sweet band clamp mount. It was a temporary solution.
Old Jun 7, 2010 | 10:02 AM
89ROC-Z's Avatar
Put the tape (omg tape!) about 3 threads from the end and screw it tight. I assume your using paste or loctite?
Old Jun 7, 2010 | 10:45 AM
Yeah, I was using teflon paste.
Old Jun 7, 2010 | 02:24 PM
Brian Coles's Avatar
Never had luck with the paste. Went to loctite and had no probs!
Old Jun 7, 2010 | 03:22 PM
Which color loctite? I'll give it a try before sending it back.
Old Jun 7, 2010 | 05:32 PM
Speed Density's Avatar
hashtagBMW
Red loctite works like a charm, the past is crap and leaves a mess.
Old Jun 7, 2010 | 10:30 PM
WS6Power's Avatar
I would replace the solenoid and use teflon tape.
Old Jun 8, 2010 | 04:09 PM
Chris@NitroDaves
Guest
Posts: n/a
Try using blue loctite...that should take care of it.
