how big of shot?
Old Jun 12, 2010 | 04:56 PM
fresh99z28's Avatar
Default how big of shot?
i have 147,000 on the clock right now, wanting to play with some nitrous, stock ls1 with a lid, is it even worth hooking it up?
Old Jun 12, 2010 | 05:17 PM
nysbadmk8's Avatar
150 max... GL
Old Jun 12, 2010 | 05:26 PM
Carter01's Avatar
From what I have always read and researched it mainly depends on the condition of the motor, not the miles. If you know the history of the car and the maint is and has been top notch I think a 150 will be fine. I have 51k on my car and i'm currently tuning for a 150 hit to start with and plan to go up until it can't handle anymore (which will be a a long time from now). Good Luck
Old Jun 12, 2010 | 05:30 PM
Brian Coles's Avatar
As long as your compression is ok then spray it. Get the proper electronics to make your kit safe. I don't have many miles as you but my stock ride loves it.
Old Jun 13, 2010 | 02:54 PM
Blk97WS6's Avatar
Go get a compression test done, and make sure you have good comp in all cylinders. Nitrous can be safe on any healthy motor as long as its done right. Use good electronics, dont buy cheap parts, etc. At the very least get yourself a window switch, and a good tune. And spray away!
Old Jun 13, 2010 | 02:55 PM
Blk97WS6's Avatar
Oh and DO NOT forget to change your plugs
Old Jun 14, 2010 | 04:47 PM
Chris@NitroDaves
Guest
Posts: n/a
What he said and i'd stick around 100hp shot and you should be good to go.
for the plug I'd suggest running BR7EF's gapped at 35
