Progressive System for Carb'd Set-up
Old Jun 15, 2010 | 03:13 PM
Ravenous T\A's Avatar
Default Progressive System for Carb'd Set-up
I have looked at some of the newer Progressive boxes from NOS, FJO, etc.. I see that it states to hook up to a TPS sensor, I having a carb do not have one, can the TPS sensor also be the WOT switch instead?
Old Jun 15, 2010 | 05:08 PM
Nitro Dave's Nitrous Outlet's Avatar
The TPS feature is an option. In your case you would choose the mode to use a wot switch and disregard the TPS feature.
Dave
Old Jun 15, 2010 | 05:40 PM
Thank you. how does the FJO compare to this unit NOS-15974NOS
Old Jun 16, 2010 | 02:00 PM
Chris@NitroDaves
Guest
Posts: n/a
The FJO is a better unit IMO and it's has an RPM or Time based ramp. THe only draw back is it's laptop tunable only.
