Pulling to many volts from the tach wire?
Once I unhooked the timing twister's tach signal, the window switch seems to work properly. Could I be pulling too many volts from the tach wire to where the window switch is not working properly when the timing twister is armed? If so.. how would one correct this to where both the timing twister and window switch can be activated at the sametime?
