Nitrous Problem
Problem: When I have the car running and the system armed, if I click the WOT switch, the fuel solenoid begins spraying but the nitrous doesn't. Also, after I let out of the WOT switch the fuel keeps spraying? When I just have the system armed with the car off, I can hear both the fuel and nitrous solenoids click. I have checked and rechecked my wiring and I am almost certain it is correct. I bought this kit used almost a year ago and am now just getting to putting it on. Could I have faulty solenoids, or am I still looking at wiring issues. The nitrous bottle pressure is at 950 when doing these tests which is close to ideal. I cannot figure out why the fuel would stay on after I "declick" the WOT switch and why the nitrous doesn't engage? I have tested the relay ports with a test light and every part of the system seems to be getting power when it needs to. Please help!
How long is the fuel spraying after you come off WOT? I think the fuel spraying was covered in another thread a few days ago too. Some coming out after deactivation is to be expected, too much could definately be a problem.
Are you triggering the WOT switch by hand, no binding issues or anything right?
As far as the fuel. It still comes out full blast after the WOT switch is "declicked". There are no binding issues on the WOT switch b/c I am pressing it by hand.
Just remove the top nut with a wrench, take off the coil. If you don't have a solenoid wrench, use an adjustable wrench and grip the stem tight and loosen it. You don't want the wrench slipping and making big gouges in the stem.
It threads right out. The only parts on the inside are the plunger, a small spring and the o-ring. It should be easy to check for debris then.
You could also try to unhook both sides of the solenoid and blow some compressed air backwards through it. See if any junk comes flying out the supply side.
