ideas on Installing nitrous on a Procharged engine
Old Jul 1, 2010 | 08:53 PM
BigRich954RR's Avatar
Default ideas on Installing nitrous on a Procharged engine
Could You install a kit to spray nitrous right after the intercooler on a procharged engine. guessing it would be a wet kit ?
Whats the best way to add nitrous to a supercharged engine ?
Can you do a no2/meth spray ?
Can you have it so it ramps up ? in hp smoothly
Old Jul 2, 2010 | 02:59 AM
Pwebbz28's Avatar
You can do so and many do. You wont need much to pick up big power though. Whats the setup? What are your IAT's now?
IMO best way to introduce nitrous with FI is DRY
Old Jul 2, 2010 | 06:15 AM
RsSean's Avatar
Yes you can use nitrous with a FI car. A friend of mine had a snow performance meth kit and a 75 shot on a turbo car.
A progressive system will allow you to ramp up the spray smoothly.
Old Jul 2, 2010 | 04:47 PM
Chris@NitroDaves
Guest
Posts: n/a
Originally Posted by BigRich954RR
Could You install a kit to spray nitrous right after the intercooler on a procharged engine. guessing it would be a wet kit ? A wet system is prefered correct
Whats the best way to add nitrous to a supercharged engine ? IF you didn't want to run a plate setup the next best thing unless you plan on spraying 200+ hp would be a single nozzle system
Can you do a no2/meth spray ? Yes you can
Can you have it so it ramps up ? in hp smoothly Yes you can have the nitorus ramp progressivly
Answers in red
