Thinking About Spraying.. Need some help please!
I'm thinking about throwing some giggle juice in the 'ol WS6. I recently just did a rebuild.. here's a brief list of specs..
LS6 Block with 39K miles
4L60E w/ 39K miles
PRC Stage 2.5 LS6 Heads
Torquer V3 Camshaft
Fast 92MM Intake
Nick Williams 92MM Throttle Body
FAST Fuel Rails w/ 36# FAST injectors
Holley 255R fuel pump
SDPC Double Roller Timing Chain
Stock bottom end
Stock 10 Bolt (no issues)
Car has about 410RWHP on a Mustang dyno..
What kind of kit would I want? A Dry setup? I imagine I wouldn't want much more than a 75 shot so I don't break anything, lol.
Could you guys help me out? Pick a kit, show me what else I would need, stuff like that.. Would I need to adjust anything
Thanks everyone.
I personally recommend the Harris speed Microedge as your nitrous controller. It has everything, except a timing retard, all in one device. Look into it.
I recommend a Bottle Heater, Nitrous Pressure Pressure Gauge (mechanical or electric), and Purge kit.
the first time i'd ever been in a car with spray was in my neon that i bought brand new off the showroom floor. i had 10k miles on the car and wanted more power. with the turbo being new i dont like the idea of ripping out a perfectly good working turbo to go bigger. so n2o was my answer, and with it being my daily drive and only car at the time i wasnt about to blow it up. i read for weeks on srtforums about how spray would work on a turbo car. well lets just say the car has 65k miles on the clock and i cant even guess how many bottles through it, and the car still runs and drives everyday flawlessly. i made 360 whp and 407 wtq on a stage one car with bolts ons and a 75 shot. im still on stock clutch, and axles, both of which people making way less hp then me break all the time.
I'm looking around the N20 Outlet site.. they have some cool *** stuff. From what I understand, a dry kit goes through the induction system, and a wet kit through the fuel rails? Could anyone post pics of their kits/controllers?
Could anyone link me to a dry kit (or give me a part number) and tell me what else I would need with it?
Thanks again everyone, you've all been quite helpful
"Wet Kit" - nozzle or plate mounts in the intake tube between the MAF and the Thottle Body. Sprays Nitrous and Fuel from the nozzle/plate in to the intake. The kit supplies the extra fuel needed for the nitrous, which is pulled from the fuel rail.
"Dry Kit" - nozzle mounts in the intake tube between Air Filter and MAF. Once nitrous sprays and passes thru the MAF, the computer thinks the engine is sucking in Denser air, therefore supplies the extra needed fuel thru the Injectors.
If you use a Dry Kit w/ a Plate (that mounts behind TB) then you will need some type of electronic Interface that tells the computer how much fuel to add and when to add it.
Each have there pros and cons, but as long as you are staying under 250 hp Shot, either will work with your setup. Anything above 250hp shot it is recommended to use a Direct Port kit for maximum and accurate distribution.
As for as which kit..... just call Nitrous Outlet and Dave will be More than Happy to walk you thru it. I promise you wont be the first nitrous noob to call.
