Damn.. Bottle went empty?
Today was the day I was going to spray for the first time. I changed out to the br6ef plugs and when I went to place my newly filled bottle of 2 weeks ago it felt real light. I put the bottle on the scale & it says 15lbs. I lost 9 lbs. since I tested out the noids for function & to which I found 2 leaks along the way by the filter hookups (it was not tight enough). I tightened all that up at that time & it looked good. I took out the bottle & left it in the garage until today. I know I may have lost few lbs when testing the sytems but not that much. How to check for slow leak without filling bottle with nitrous? I did close the valve when I stored it. Its a brand new bottle. The bottle only has a blow down tube & a pressure gauge attached to it. Edit: just realized it sounds like you lost it all. You dont have to have the bottle filled completely, maybe a pound or two, see if the store will let you use their bathroom sink or spray some soapy water around the fittings.
