Nano leaking
Old Jul 10, 2010 | 02:33 PM
2500HD6.0's Avatar
Exclamation Nano leaking
So I get my new nano kit in the mail and I can hear it is leaking so I try to tighten every thing up and the leak gets worse. I did notice a small pin hole on the back of the nano gauge that it is coming from is this right? It lost 500 psi over a few nights. Yes it did come full @ 3000 psi.
Old Jul 10, 2010 | 02:41 PM
2500HD6.0's Avatar
Ok it's also leaking from the gold port that says 3k on it. It's lost 500 psi in 8 min. It is tight what's the deal
Old Jul 11, 2010 | 02:40 PM
danger ds's Avatar
Maybe the burst disk inside the neck busted. I was told by the guy that fills my nano bottle if you unscrew the bottom part of the bottle there is a burst disk in there and when it fails it can leak out. He said that fixing it is not hard, he has the parts on hand all the time. Hes the paintball place in Luling.
Old Jul 11, 2010 | 11:46 PM
2500HD6.0's Avatar
Good deal I will check into that
Any new times with your new set up?
Old Jul 12, 2010 | 08:26 AM
Brad@NANO Direct's Avatar
Sent you a pm.
Old Jul 12, 2010 | 09:24 AM
RsSean's Avatar
can we get some information on this in case the issue comes up with someones else.
Old Jul 12, 2010 | 09:37 AM
If its coming from the gauge, it is a defective gauge. The pin-hole is a bleed off to show the gauge is bad.
Would be glad to send you out a gauge under warranty.
Old Jul 12, 2010 | 10:30 AM
danger ds's Avatar
I went to midnight madness sat but I couldent get the nitrous to fire off
I check my tick box and all the numbers looked in order but still no go on the spray. When we left I checked my wot switch at a gas station and on of the wires seemed loose so I decided to continue the test and tune on the way home and the car fired off with out a problem. I will be going back to the track wed to try again.
