nitrous out let ! i need your help
Old Jul 18, 2010 | 11:20 PM
PONTIAC SLP's Avatar
Default nitrous out let ! i need your help
Hi , i'll run two stages for my new setup , the first stage is TNT F2 (150HP) , Second Nitrous out let direct port system with 4 solenoids (350HP) , my qs is : i have fast intake 102mm ported to 105 and i have the 78 ring , how can i mount the dual TNT nozzles ?
Old Jul 19, 2010 | 09:54 AM
Nitro Dave's Nitrous Outlet's Avatar
Using the nozzles you will disregaurd of the ring that came in the TNT system and put the nozzles in the air bellow before the throttle body instead. To do this you will need to nozzle adapters to lock them in place.
http://www.nitrousoutlet.com/catalog...5&product=3783
Or you can upgrade to a plate.
Dave
Old Jul 19, 2010 | 10:28 PM
Dave
oh **** , i didn't ordered them with my last order so i'll buy them on my next order , thanks Dave
Old Jul 21, 2010 | 12:48 PM
Dave
how much will cost to convert the TNT kit to nitrous out let plate kit ?
Old Jul 23, 2010 | 04:07 PM
Chris@NitroDaves
Guest
Posts: n/a
The 102mm plate conversion is $285 and the misc fittings that you would need will be around $20 because you could resuse a couple of the lines form the TNT setup.
