hows this for a nitrous cam?
Old Jul 23, 2010 | 06:30 PM
slayer performance's Avatar
Default hows this for a nitrous cam?
236/244 .630 .630 113 LSA and 111 ICL
the motor will be:
ported 799 heads
forged internals
200+ shot
ls6 intake
11:1 compression.
the car weighs around 3280lbs and has a 4000 vig nitrous converter.
does this sound like a good combo?
Old Jul 23, 2010 | 08:32 PM
BLK02WS6's Avatar
What cubic inch?
Old Jul 23, 2010 | 08:49 PM
stock cubes.
i have decided to go with a differant cam, it would be to lazy on motor (but totally bad *** on a 200+ shot) i am considering something more around 112 lsa and 108 icl
Old Jul 26, 2010 | 01:52 PM
Chris@NitroDaves
Guest
Posts: n/a
On the new cam are you sticking with the same durration and lift or are you completely changing it up?
Old Jul 27, 2010 | 05:39 PM
i am completely changing everything, cam wise. and going with a patriot stg 2 ls6 heads.
Old Jul 27, 2010 | 06:18 PM
BAKED's Avatar
I'd take the ported 799's over the Patriots... Just my opinion though.
Think a little smaller on the cam choice. Bigger isn't always better.
Old Jul 27, 2010 | 06:52 PM
i know i have smaller cam now but with the higher compression and big stall plus lighter weight, a bigger cam can be used.
Old Jul 27, 2010 | 09:03 PM
BAKED's Avatar
Any cam can be used, I just havent seen any benefit to running a cam that big on these setups.
Let us know how it does....
Old Jul 27, 2010 | 09:06 PM
as i said i am going with a totally differant cam, it would be way to lazy on motor.
im not trying to offend you, what would you run?
Old Jul 27, 2010 | 10:17 PM
Dirty Vegas's Avatar
What do you run now? ET wise?
Old Jul 27, 2010 | 10:20 PM
i haven't ran this setup yet but i will soon.
Old Jul 27, 2010 | 10:24 PM
You haven't ran your setup, but you want to change it? What does the car currently run right now? What is your goal?
Old Jul 28, 2010 | 07:38 AM
BAKED's Avatar
The cam in my ar is prett close to the size of a G5X2, mine is on a 113. I am running a set of ported 853's and a single plane ported by myself and a carb. My motor is 11.2:1 and with open headers it made 435rwhp through the stalled auto and 9". The torque was kinda low 365 I think but overall the car done pretty good, especially on the hose.
