direct port on standard manifold
Old Jul 24, 2010 | 11:46 PM
turbodlsx's Avatar
Default direct port on standard manifold
hi there iam after some help i wont to setup a direct port nitrouse kit on my standard ls6 intake manifold where is the best place to drill and tap for the foggers in the manifold and what is the best fogger for the job any help would be a huge help and if anyone has any pictures they would be much appreciated
cheers
Old Jul 25, 2010 | 08:28 AM
BAKED's Avatar
Basically you want the nozzles to be spraying directly at the intake valve. Make sure they are all the same distance up in the runner and make sure that they are all installed at the same depth. Don't just count the threads either. Make some sort of gauge to check how much of the nozzle is protruding into the intake runner.
HSW and Nitro Dave have alot of good pics on their sites.
Old Jul 25, 2010 | 09:09 AM
turbodlsx's Avatar
cheers for that yeah just no one knows anything here in australia or new zealand. so tryin my hardest to sus it out first as this is my first nitrous venture haha. i will also be usin the lingenfelter lnc-2 for the timing etc.
Old Jul 26, 2010 | 10:48 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
We have a local vendor in Australia that we really like. Hes a good guy that can help. I will pm you his number sir.
Old Jul 26, 2010 | 11:30 AM
Nitro Dave's Nitrous Outlet's Avatar
cheers
We plumb alot of intakes. It has been a while since we updated our photo gallery but there are enough LSX style intakes on what is currently posted to see what will work best for you.
Click Link.
http://www.nitrousoutlet.com/installs/index.asp
With the LS6 intake the idea spot is to the left of the fuel injector bung. You have to keep in mind the pitch of the nozzle needs to be high enough to clear the coil brackets but low enough to clear the fuel rails.
We could easily plumb an intake and ship it to you. We do this all the time. We also have two dealers there in Australia that we could refer you to.
If you want us to plumb one for you, you can either send us your intake or we can provide one for you to save you the shiping of sending yours in. We can plumb it and flow it.
We have alot of different styles and options and can custom build to your exact needs and wants.
Dave
