N20 and lsx?
Old Jul 25, 2010 | 12:59 AM
GoFastKid's Avatar
Default N20 and lsx?
I was considering getting a Nitrous Outlet Wet Plate set up and doing either a 75 or 100 shot. How do the LSx engines respond too and handle the juice? The car is a 2001 ws6 w/ 45K full bolt on's LT's etc etc Would I need bigger injectors with a 75-100 shot? Stock fuel pump ok?
Old Jul 25, 2010 | 02:18 AM
billymz28's Avatar
They love it I am running a 100 shot on my vette and steping up to a 150 after a fuel pump. I have headers and stock mufflers. I am running the n20 outlet wet plate kit also. Just pull some timing and put n20 plugs in the car and you will be fine. No you dont need bigger injectors. I am on stock pump also. Seen my buddy spray a 150 shot on a bone stock 04 gto.
Old Jul 25, 2010 | 03:07 AM
Snake_Skinner's Avatar
^^^Do you know what kind of numbers your friends bone stock goat was putting up with that 150 shot?
Old Jul 25, 2010 | 07:19 AM
custm2500's Avatar
Ph.D. in HUBRIS
You say you have full bolt ons you might want to look into a better fuel pump. Your injectors are probably ok but the pump will probably struggle to keep up with the power you are making now and another 75+ of nitrous.
Aside from that the motor will love it.
Old Jul 26, 2010 | 02:23 PM
Chris@NitroDaves
Guest
Posts: n/a
If you have heads/cam in the car then you will need to upgrade the fuel pump in the car. I'd suggest getting a Racetronix kit http://www.nitrousoutlet.com/catalog...3&product=3721 and http://www.nitrousoutlet.com/catalog...0&product=3318 . Being a wet system if the injectors will support what you have now it will be ok on nitrous.
These motors love nitrous!!!!!!!!
