Breaking in motor question
Old Jul 25, 2010 | 06:20 PM
Maroslut2001's Avatar
Default Breaking in motor question
Should i break in my motor with a set of tr55's and then later on switch to the br7ef's or just go ahead and break it in with the br7efs??? i wont be running nitrous until the motor is broken in and it will be no more than a 125 shot.
Old Jul 25, 2010 | 06:42 PM
BLK02WS6's Avatar
I would break it in on the 55's - it'll probably burn a little oil till the rings seat in, and that'd kill the 7's quicker... Just make sure to change them before you spray it.
Old Jul 25, 2010 | 07:36 PM
Cool, thanks for the help!!!
Old Jul 25, 2010 | 08:24 PM
elias_799's Avatar
+1 for the tr55's
you should not be spraying on a motor that is being broken in anyway
Old Jul 25, 2010 | 09:31 PM
Ya i am not planning on spraying it until i have the motor broken in, and then just starting out with a 100 shot....
A little off topic but i also am looking for a good setup to use with a zex system. I want to add a 2 step, timing retard unit and a window switch. Can anyone point me in the right direction for these units??? i was maybe looking at the lnc-002 and adding a msd window switch... Will these hook up to the zex kit easily? and can i shut off the timing retard and still use the 2-step if i want to launch on the 2-step and not use the nitrous???
