HSW switch question.
Old Jul 28, 2010 | 10:48 PM
99_Z_155's Avatar
Default HSW switch question.
ok, i have the brute force wet kit setup. i decided to clean the wiring setup up and get some different switches.
i want to use a toggle switch for the arming function that only has 2 terminals on it. the schematic from HSW shows a 3 terminal switch for that function with a ground. whats the purpose of this ground? is it to ground the switch if it has a light inside or something? does it ground the WOT switch out, if so, why does it need a power lead? im confused here.
Old Jul 28, 2010 | 10:56 PM
1_bad94Camaro's Avatar
its for the led light. i used 2 terminal switches on my car
Old Jul 28, 2010 | 11:00 PM
99_Z_155's Avatar
thank you sir, thats all i needed.
Old Jul 28, 2010 | 11:19 PM
not a problem. i used my own switches because they were a lot smaller and i could hide them better
