Which Plug ?
Old Aug 23, 2010 | 08:38 PM
Fast 2010's Avatar
Default Which Plug ?
Got a 2010 Camaro. Cam.. headers.. CAI.... Nitrous outlet plate set up. 430 HP without the spray. Planning on a 150-200 shot. Mainly a daily driver. Wondering what plugs and at what gap.... TR6's or BR7EF's ?
Old Aug 23, 2010 | 11:27 PM
dnkynrbk's Avatar
a 200 shot I would get the the #8s if you do a 150 shot #7s. Do not use 6s
Old Aug 24, 2010 | 07:28 AM
ryarbrough's Avatar
Agreed... even the 7 is too hot for that much spray
Old Aug 24, 2010 | 08:58 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Agree with these gentleman. Tr6's are definitely the wrong plug. A br7ef will work fine NA and will do well on the spray. Moving to the 200 shot is #8 heat range territory.
On the gap, I would pull them out and make sure the gap is all the same out of the box.
Old Aug 26, 2010 | 03:45 PM
Chris@NitroDaves
Guest
Posts: n/a
I agree with all above. We have had customer's use 7's on 200hp hits but if you wanted to be on teh safer side of the line i'd use the 8's on the 2010.
Old Sep 1, 2010 | 12:13 AM
z28kidd's Avatar
will the 8's be ok for N/A? i dont plan on spraying a 200shot very often
Old Sep 1, 2010 | 12:19 AM
z28kidd's Avatar
Old Sep 1, 2010 | 09:33 AM
justinj's Avatar
Same out the box? What would that even be gap to?
Old Sep 1, 2010 | 09:39 AM
ryarbrough's Avatar
Run the 8's from .032-.035. They won't hurt performance off the bottle as long as the tune is clean.
