3 questions for a friend?????
Old Sep 9, 2010 | 05:15 PM
LTXBOI's Avatar
Default 3 questions for a friend?????
1rst question can you mount a 10lbs bottle horizontal?
2nd quetion how long does it take to heat up bottle with the warmer blanket?
3rd question is it safe to just activate bottle warmer with ignition?
pros/cons of each question would be great...
Old Sep 9, 2010 | 08:20 PM
krissoto's Avatar
There are syphone tubes in the bottles,so best way it with the valve slightly elevated, I have seen other do it tho.
Each bottle is diff, depends on how hot/cold it is outside, how much nitrous is in the bottle, and how hot/cold the nitrous is inside the bottle. Thats where a guage comes in handy.
And to the third I guess Im not sure what your saying? When the ign is activated it would turn on the warmer, You need a way to regulate it, whether its thermostatically controlled or just on a toggle. Too much heat will blow the disks..
Hope this helps..
Old Sep 9, 2010 | 09:29 PM
LTXBOI's Avatar
Hope this helps..
so would that be a pressure gauge...greatly appriciated for the help!!
Old Sep 10, 2010 | 03:58 PM
Chris@NitroDaves
Guest
Posts: n/a
Originally Posted by LTXBOI
1st question can you mount a 10lbs bottle horizontal? You can but as stated above you will need to elevate the bottle a little and also have the main feed hookup facing slightly forward so on acceleration the siphon tube is in the liquid nitrous.
2nd question how long does it take to heat up bottle with the warmer blanket? As answered above there really is no set time frame because there are so many variables but i would say newhere from 5-25min depending on outside temp.
3rd question is it safe to just activate bottle warmer with ignition? I wouldn't do it this way in case the car is left on..it's better to put it on a switch you can trun on and off.
All answer's in red.
Old Sep 12, 2010 | 02:00 AM
LTXBOI's Avatar
final question bottle will be mounted under dash on pasenger side area do i have to remove bottle for refills?
Old Sep 12, 2010 | 02:26 AM
LTXBOI's Avatar
thanks a lot chris!!!
Old Sep 12, 2010 | 10:20 PM
1_bad94Camaro's Avatar
I agree with chris. I recently installed a heater on a C6 that had a pressure switch on it so if the owner of the car forgot to turn off the heater switch it would turn off by its self on high pressure.
as for your question about having to remove the bottle for refills yes you would.
I freeze my customers bottles for about 2 hours so they fill easily.
Old Sep 15, 2010 | 04:04 AM
LTXBOI's Avatar
thanks man!!!
Old Sep 15, 2010 | 04:34 AM
joeys99z28ss's Avatar
buy a pressur switch for the heater and make sure the bottle is open any time the heater is on
