Low fuel pressure cutoff
Old Sep 11, 2010 | 09:47 PM
C5Munch's Avatar
Default Low fuel pressure cutoff
I have a fuel pressure gauge that will send a 12v switched signal if the pressure gets below a set psi. The gauge recommends this switched signal be connected to a relay to activate whatever I want. How would I use this to kill the nitrous if there was a pressure drop? I am using the Microedge if it matters.
Thanks
Old Sep 12, 2010 | 09:22 AM
gillbot's Avatar
just put it in line with the solenoid control circuit so the normally closed relay is opened if the pressure drops. This will cut power to the solenoids.
Old Sep 12, 2010 | 10:56 AM
joeys99z28ss's Avatar
dyno jet webs site has a wiring diagram for that
