nitrous question-RPM switch relate
Old Sep 19, 2010 | 10:05 AM
c6 batmobile's Avatar
Default nitrous question-RPM switch relate
Okie dokie here is the problem. I have wired my nitrous system up completely. Every thing works as advertised except the WOT/RPM window switch. Its a NOS brand switch. It fires up when the system is armed and I programed it to be on at 3000 rpm and off at 6000 rpm. I used the falling signal for TPS input and set it to 1.2 volts. Set the cylinders to 8. Now here is the issue it only reads HALF of the rpm the car is actually at. I.E. my car idles at 900 and the WOT switch only reads 450 when you rev it to 3k it reads 1500. Any ideas what could be causing this? I thought that it may be the cylinder settings thinking there are more but I dont know.
Thanks in advance.
Old Sep 19, 2010 | 10:33 AM
dnkynrbk's Avatar
You need to set the cyc to # 4 not 8 cyc. trust me.
Old Sep 19, 2010 | 10:34 AM
dnkynrbk's Avatar
If you have any more questions let me know I just set this kit up for a guy 2 weeks ago. I can walk you through it to
Old Sep 19, 2010 | 11:02 AM
Ok awesome. That is what I thought.
I also dont know how to set up the nitrous management unit. It says it need to be put into learn mode but it does not operate without the engine running because I set it up with a relay so that it is impossible for the nitrous to fire without the WOT switch telling the relay to open the NMU. Does it even need to be programmed?
Old Sep 19, 2010 | 11:11 AM
1fst4dr's Avatar
What kit are you running?? Zex??
Old Sep 19, 2010 | 11:20 AM
ZEX with a NOS WOT switch.
