Went to atco rental on the 7th track was hooking so I put the 200 jets in the plate kit and let herbrip first two passes went right for the bumper wild ride.Tightened up the front shocks two clicks and got it to leave just a little wheels up hit a 1.25 60 ft
car went 5.95 in the 1/8th threw the 1/4 it went 9.39 at almost 142mph on the limmter 100 ft before the traps.I had seven passes below the 1.30 60' averaged 1.27's not bad for stock suspension style set up this was on mickey 325 drag radial too.I thing its got 9.20's in it just have to tighten up the converter some
car went 5.95 in the 1/8th threw the 1/4 it went 9.39 at almost 142mph on the limmter 100 ft before the traps.I had seven passes below the 1.30 60' averaged 1.27's not bad for stock suspension style set up this was on mickey 325 drag radial too.I thing its got 9.20's in it just have to tighten up the converter someThanx man congrats on your new best car goes well into the tens on motor.
Dave what rear gear is in the car? You might need to make a change there rather then changing the converter. Radial's don't have any growth at all, between that and if you still have the 4.10 gear in the car, that's why it's on the limiter.
A set of 3.73's will give you the room you need, I'd do that before touching that converter. Either that, or put a set of the 295/60's on , that's the 30 inch tall size tire. Probably gonna need a minitub for that though.
Will tightening up the converter with the john deere tranny fluid make a difference?
Quote:
Congrats on the times! Nice 60ft. Any more info on the john deere tranny fluid?Originally Posted by INTENESS
