Nitrous And Transbrake Wiring Hookup
Cheers Dean
NOS Single Stage Plate System- Cheetah
Nitrous Progressive Controller Part # 15835BNOS
Purge
Nos Thermostatically Controlled Bottle Heater
Transbrake
Wot Switch
Fuel Pressure Switch
PROXT is online now Report Post Edit/Delete Message
You need to know the total amp draw of all your solenoids combined to determine the correct relay.
If you install a 5 wire relay inline with your micro switch and nitrous relay, then activate it buy wiring it to your transbrake button, you'll be able to deactivate your nitrous while on the T-Brake.
A 30 amp 5 terminal relay would probably be sufficient.
You should always verify your total amp draw from all solenoids regardless...
FWIW... NOS usually supplies a 5 terminal relay with a 4 wire pigtail with their systems. You just need to add 1 wire to the connector.
