need some advice
Old Oct 12, 2010 | 09:43 PM
millersta's Avatar
Default need some advice
here is the deal right now i have a halo kit from nitrous daves and im looking to go to a wet kit. my delema is i can get a ls6 moneymaker intake or i was thinking of going to a plate kit from nitous outlet. pros to the money maker are its an ls6 intake and i dont have to buy a new intake. if i go with the plate i would be getting an 85mm because i can get a good deal on an 85mm typhoon intake and i think it may help should i decide to go heads cam. what do you guys think.
Old Oct 12, 2010 | 10:02 PM
BOTTLEFEDLS1Z's Avatar
Go with whatever is gonna help you power goals and your wallet.
I've had both the money maker and a Nitro Dave's plate. If you want to keep the kit hidden, then the money maker is your friend, if not get a plate kit.
Old Oct 12, 2010 | 10:23 PM
millersta's Avatar
keepin it hidden isnt a huge deal. money wise i w\ould probally save $300-500 goin with the money maker but if it wont be as good as the plate then i would rather spend the extra cash. im hopein to spray about 200 which would be better for that
Old Oct 12, 2010 | 11:52 PM
I'd go with the money maker if your saving $300-$500.
Both are perfectly fine for a 200 hit, but you can spray more with the money maker. I've sprayed a 250 thru the plate and no issues, but thats alot going thru it.
