Plate or nozzle?
What is the cheapest and easiest way to take timing out of a Ls1? Want to run a 150 shot, So that would be 6 degrees right?
2 degress for every 50 shot is a good rule. I would upgrade you stock fuel pump and get colder plugs to NGK non proj. plugs.
I personally wouldn't use a handheld for anything. I don't even touch them so I don't know if any of them can pull timing for you.
1. Plate ( Better atomization and distribution over a nozzle )
2. Lingenfelter Timing Controller is the best on the market for pulling timing.
3. NGK BR7EF ( Stock # 3346 ) is the correct plug to run
4. The general rule for timing is 2* Retard per every 50 hp
Here is their reply
Thank you
