nitrous install help
Hey wussup guys Im having alot of trouble installing the full throttle micro switch Its nowhere to mount the damn thing. I was wondering if I could run a rpm window switch instead of the full throttle micro switch it would save me a headache. Its a kit from nitro dave. Its the brand x ls1 kit. Help thanks guys
You need the WOT switch and a window switch, iirc some window switches come with a WOT switch built in. What type of mount does your switch have? If its like the mini solenoid mount you can mount it to the throttle body bolt.
I can get you a picture of mine if you wait till tomorrow. I believe I put my bracket and switch on one of the Throttle/Cruise control cable bracket bolts. The WOT bracket has an S bend in it and lines it up.
thanks guys. @wfritts911 yea that would be cool to see some pics so i can get a clear picture thanks. email lamontmccorkle89@gmail.com
http://s990.photobucket.com/albums/a.../WOT%20Switch/
Dont mind the dirtiness of the engine bay, I'm to scared to wash it lol. But anyways you should be able to see from those pictures how I mounted my WOT Switch, appears to work good.
-Will
-Will
Guest
Posts: n/a
We offer specific Micro Switch brackets for the F-Body ( http://www.nitrousoutlet.com/catalog...=23§ion=92 )but if you wanted to get a window switch that has a TPS feature then you wouldn't need to run the micro switch.
