Anyone spraying through the gears?
Mine is only on WOT switch. The spray is on from the moment I go WOT and thru each gear change.
To the OP, I would just not hit it out of the hole and wait til you get out a lil ways in 1st gear then hit it. Only hit it with a 100-125 thru the gears but any more than that I wouldn't spray thru the gears, unless you have money to go get your trans built. You will run faster though if you spray thru the gears.
