how much nitrous could I spray ?
Currently 11:1 CR 100% n/a with stock rotating assembly except for cam .....signature has add'l info - spray would be used from 30-40+ roll due to still having not upgraded my rear end.
Is a 75-150 shot realistic based on my stock internals and 11:1 CR?
I know I;d need a tune which is NP - fortunately I have a great tuner.
I've also been told I'd need to upgrade my fuel system or a dedicated - which I don;t completely understand- hoping some one can explain specifically what upgrades of fuel system would be required?
Also what getting a dedicated would mean in this context?
Thank you in advance for your feedback.
NOS = a Company, not the gas. (FYI, avoid using NOS to describe the shot, people tend to get FLAMED for it here).
Nitrous Oxide is what you combine fuel with to put into the motor.
75-150 hp shot is the typical range for a LS1, there is leeway but to be safe, start with 100 and go from there. Some state you can do 200, but the issue is all kits are rated differently and really going by pill size is considered more accurate.
RPM will matter more then what MPH your driving. Also the RPM you should be at may still break the tires loose badly. You maybe better off with a push button activation switch rather then a WOT (wide open throttle) switch.
Having a good tuner is optimal, just make sure he knows LSx and Nitrous.
Most, including me would recommend a Wet shot, which uses a combined mixture of Nitrous and your fuel to make the shot. Diff between Wet and Dry is what sent into the intake. The "Dry" kits rely on fuel coming from the injector. IMO I want fuel and nitrous when I need it, and unless I spraying nitrous everytime I get get take out or going to the grocery store, the fuel maps do not need to be overly rich to compensate for the dry hit.
As for fuel upgrades, if staying Wet, then most times you get a 255 LPH fuelpump with a hotwire kit. If going dry you get that + injectors. As for a dedicated fuel system, IMO is VERY good at helping create a window of safety for Nitrous use.
In a normal "Wet or Dry" shot, your using your current fuel in the fuel tank which often is 93 Unleaded Octane. It's resistance to detonation is better then lets say 87 octane but not nearly as good as higher grade unleaded or leaded fuels.
What I plan on doing is when my kit goes on is getting a dedicated fuel cell for Nitrous only. Harris Speed Works sells a kit, so research them. The best part is when the Nitrous is activated that not only do I run my normal 93 oct. fuel, that the nitrous will be spraying a dedicated leaded fuel to open up that safety window. Mine will likely be C16.
Simply put that dedicated means that only leaded C16 race fuel goes in there so there is not having to "Mix" fuel at the track and hoping it works and this diminishes chances that left over mix fuel can foul up o2 sensors and CATS.
Also to mention you will need to change your spark plugs to a colder one. I am a NGK fan, but Autolites are a popular choice.
I still say go over to the Nitrous Spec section if you have more questions.
Good Luck!
Is a 75-150 shot realistic based on my stock internals and 11:1 CR? Many of us spray well over 200 on bone stock rotating assemblies, it takes allot of research but it's worth it
I know I;d need a tune which is NP - fortunately I have a great tuner. if your na tune is spot on then a retune won't be necessary if you run a wet kit, you will tune your fuel by the jet. However you will need access to adjust the timing regularly
I've also been told I'd need to upgrade my fuel system or a dedicated - which I don;t completely understand- hoping some one can explain specifically what upgrades of fuel system would be required?Most of us run the Racetronics 255 in tank replacement with a Hot Wire kit, should hold up 650 rwhp give or take
Also what getting a dedicated would mean in this context? A dedicated fuel cell is basically a small 1-2 gallon fule cell that rides up front under your hood. This setup allows you to run pump gas in the tank and high octane race gas in the cell. The cell basically feeds the fuel solenoid on your nitrous kit and helps prevent detonation. This kit is has to be tuned differently due to different fuel pressures than stock. For a 75-100 kit I don't see any reason to go dedicated
Answers in red
Now I'll let someone with the answer post up, sorry
