Ok need to know if this fuel setup will work?
lt1 car with nitrous, should make 500-575hp on motor then add another 250+ of n20. Need to know if 2 fuel pumps in the tank will suffice? ALso can a hobbs switch be used for this or just have both pumps turn on the exact same time with Key on? What do you big shot guys do?
thanks
thanks
If you do it right two pumps will support 1k hp. A Hobbes switch won't do you any good on a nitrous situation. You'll need to turn the second pump on with the nitrous arm switch
exactly, Just use the 2nd pump when you activate the spray or you can use a stand alone and ONLY 1 pump
