Sort of a newbie question...
I have the same setup as you but with out the nitrous....What besides the tnt-F1 did you have to add to make the nitrous SAFE
sounds like your buddy just has a bad case of sand in the vagina. get him a moist towellet to get that **** outta there. Nitrous is a great mod. it really is the best bang for the buck, and its only gonna cause problems if your buddy is slightly retarded.
To answer your question camaro, on a small shot like that either of them would be fine. A stock car / fuel system can easily handle a 100ish dry shot with little or no effort. A wet shot is good for larger shots, as it will stop the car from running lean, which is the major concern when running nitrous.
- simple wet system ... adds fuel and nitrous into the intake ...
------ up side is that it is great for larger shots and hits harder (weeeee) ... downside is that it can pool in the intake if you run it at too low of an RPM and explode, and hits harder (more broken parts).
- simple dry system ... just nitrous is added, usually before the MAF.
------ very simple to install, easy to use, and comparitively safe when running a smaller shot. Downside is that the shot size is limited by the stock fuel system, and you run more of a risk of running lean.
- direct port system .... ohhh baby hold on.
Personally, I would tell your friend to go with a dry shot if he was planning on spraying under around 100hp on a stock car such as that one. If he wishes to spray over that amount, he should probably go with a wet system.
