How to hook up WOT switch?
Old Feb 4, 2004 | 05:12 PM
rickou812's Avatar
Question How to hook up WOT switch?
How do you guys hook up the WOT switch? I am installing the TNT F2 system that came with a solinoid mounting bracket that mounted using the throttle linkage bracket mounting bolts. I can't find a decent way to mount the wot switch any where. ANY IDEAS will be appreciated.
Old Feb 4, 2004 | 07:51 PM
Black02SS's Avatar
I don't know if this is what you are looking for or not.
Old Feb 4, 2004 | 09:40 PM
NaughtyIROC's Avatar
Here's an alternate WOT switch ......much nicer looking than the generic one and just bolts right on......
R
Old Feb 5, 2004 | 06:40 PM
rickou812's Avatar
Thanks guys, that was exactly what I was looking for. Loks easy now that I SEE it.
Thanks again
Old Feb 5, 2004 | 09:10 PM
Randy WS6's Avatar
Thats how mine is to , i use the ground wire to activate the switch one side to body and the outher the relay works grate
Old Feb 5, 2004 | 11:03 PM
14u2nv's Avatar
Doesn't NX offer an electronic TPS (throttle position sensor)switch rather then a WOT switch?
Old Feb 6, 2004 | 07:26 AM
Fast SS on TNT's Avatar
I bought one from Jimmy Jams. It is way better then the stock piece. It wount bind up in your damn throttle cables. It sits off to the side, notice the stocker has the wires going right between the cables....that is a shitty position, and it will cause wire chaff.
