What kinda base timing should I run?
I am preparing to spray it with a 175 shot and so far I have non projected -9 ngk plugs, a stand alone fuel system set at 5.5lbs of pressure and 110 octane race fuel. Was thinking of pulling about 7 degrees of timing at first to start putting me around 27 degrees of total timing. This sound reasonably safe??
I would pull 8 degree's. This will almost certainly be overly conservative, which is where want it. Since you are just getting started with your tuning I would like to see you on a 10psi tune up to start with. This is partly just personal preference.
Post up a overview of the system as well as goals for the car.
The kit itself is a n2o outlet kit with the large (normal sized) solonoids 10lb bottle 4an feed line 3an exit lines. It was originally a single fogger kit for a mustang or something like that that I converted by adding a NOS cheater plate with nos jets.
The fuel system consists of a one gallon foamed cell with 8an bulkheads to 6an reducer feeding a pro comp 140gph fuel pump with a billet regulator.
I have a wide band in the car so I won't be in the dark on how the pass is going and won't be running it lean by no means.
Car as it sits is almost fully what an lt1 car weighs and it will run door to door with 600 wheel cobras on the motor and I have a passenger. Long term goals are to see the car into the 9s but thats gonna take a better trans and some front suspension. Rear will give before then too. Right now I just want the extra power to show off and put a few lengths on the one or two cars that give me a close run around here.
Strong running car is it is doing that on motor. Should be VERY easy to get it into the 9's with the motor pulling that hard. Let me know If you need any more input.
Graham@nitrousexpress.com
Good luck and let her eat!
