Leaky NANO Valve?
Old Dec 9, 2010 | 11:45 PM
BakaN20's Avatar
Default Leaky NANO Valve?
Hey guys,
Quick question, is it normal to get some air leakage through the NANO valve? Maybe because its pretty cold and the rubber o-ring is brittle and lets some air out? Will an o-ring conditioner help? Here is the valve I am talking about:
The one that goes in between the nano and nitrous bottle. I wanted to ask you guys first before I try a conditioner of some sort, so not to ruin the o-ring or something. Thanks!
Old Dec 10, 2010 | 03:22 PM
Brad@NANO Direct's Avatar
There should be no leaking. Send me your info through pm and i will send you a new one. I will get it sent out monday for you.
Old Dec 10, 2010 | 03:35 PM
Chris@NitroDaves
Guest
Posts: n/a
Agreed with Brad there should be no leaking of any kind.
BakaN20 your in good hands Brad will get you taken cvare of....Brad@NANO FTW!!!!
Old Jan 4, 2011 | 10:53 PM
BakaN20's Avatar
Yes, brad has always hooked me up, I can't say enough about NANO customer service. Will send you a pm. Thanks again brad!
Old Jan 6, 2011 | 04:24 PM
Chris@NitroDaves
Guest
Posts: n/a
Agreed...Nano has always been great to deal with from our standpoint as well.
Old Jan 6, 2011 | 04:39 PM
kdavis's Avatar
+1 excellent customer service and quality products
Old Jan 15, 2011 | 10:00 PM
BakaN20's Avatar
Just an update, Brad and NANO have been amazing. There is no question about their customer service, they are a great company. Everyone who has nitrous should have NANO, just for the customer service alone, lol. Thanks again for everything!
Old Apr 27, 2011 | 06:31 PM
Steadyasshegoes's Avatar
Speaking of leaks, what would cause mine to leak out of the threads of the on/off ****?
 Michael S. Palmer
Old Apr 27, 2011 | 07:57 PM
Detoxx03's Avatar
Yeah I have to agree that nano has amazing customer service
Old Apr 27, 2011 | 08:46 PM
Back to the top.
Old Apr 28, 2011 | 08:04 AM
Back to the top.
You will need to send me over your information to pm box.
Name
Address
Phone number
email
I will get you a replacement out, as soon as i receive your info.
Old May 4, 2011 | 12:10 PM
I wanted to let you know that I received the part on Monday already and can once again attest to the top-notch customer service at NANO. I thank you for this as it is greatly appreciated!
I do have a question though about sealants in tow parts. In the picture I sent above where the braided line hooks into the valve you sent me, what type of sealant do you recommend for that area? Secondly, when I screw the new valve onto the bottle, what sealant do you recommend for those threads?
Thanks!
Old May 4, 2011 | 12:34 PM
Thanks!
We appreciate the feedback!
We use a black teflon. In the past we/or customers have used locktite, teflon paste. If you use teflon be sure to get the threads only with it.
If you are speaking of threading the black on/off valve onto the NANO bottle this is a o-ring hand tight seal. This does not require any sealant. If the o-rings are dry we recommend using 100% silicone on them. You can get a small tube or can of it at your local hardware store.
Old May 4, 2011 | 02:22 PM
When you say "o-ring hand tight seal", do you mean it takes very little torque to tighten the valve to the bottle? If so, no tools required for that task?
Old May 4, 2011 | 02:24 PM
Correct, just hand tight. No tools are required for threading the black on/off onto the NANO bottle.
Old May 4, 2011 | 02:28 PM
Excellent and once again thanks for the assistance!!!
Old May 4, 2011 | 02:37 PM
You got it.
Old May 4, 2011 | 03:51 PM
AChotrod's Avatar
Agreed! Brad has great to work with!!
Old May 7, 2011 | 11:45 PM
Hello again,
I have been unable to locate the black teflon. Do you happen to know where I can find it?
Old May 8, 2011 | 05:34 PM
We special order the black teflon. If you are unable to use white let me know and I can send you a little bit of black.
