what cam should i buy help
Old Dec 25, 2010 | 12:30 AM
copperlanch's Avatar
Default what cam should i buy help
So I just got my forged ls1 back an don't no what cam to put in it car is full weight th350 trans planning on spraying at least 250 or more car will be driven on street some but mostly just drove to track . Just wanted some advice guys thanks in advance o yea it has prc stage. 2.5 5.3 heads on it
Old Dec 25, 2010 | 07:40 AM
Cold Zero's Avatar
I would say go custom unless you are looking for ( on shelf cams ) go with MS4
This section Mod (( Ryarbrough )) run MS4 in mostly the same setup with gr8 sucsess
What about ur plans for nitrous system ? For that size of shot u should be running Direct Port
Old Dec 25, 2010 | 08:17 AM
ryarbrough's Avatar
MS4 has worked ok for me... It really needs more exhaust duration to get the most out of that much spray, which is why I'm switching cams over the winter.
Old Dec 25, 2010 | 08:40 AM
Carter01's Avatar
I have had good success with my off the shelf TSP TRQ 2. It seems that having a cam speced is the way to go these days. We are putting together a Cam Only 99 TA right now that Patrick G speced out for us so I will have more insight once we get the car running. Make sure you purchase a top notch converter, it will make all the difference in the world on how the car performs on the nitrous. I had Greg at FTI spec and build mine and it performs great. Last outing on the 225 shot it went back to back 1.36 and 1.37 60fts in my 3450lb street car.
Old Dec 25, 2010 | 03:46 PM
chevboy28's Avatar
Talk to pat g on here
Old Dec 26, 2010 | 12:48 AM
Yea I am thinking about sending my intake to nx an let them plumb up there kit I talked with texasspeed a while back when I was going with a six speed they said the tsunami would b a good one but not sure since I'm going auto
Old Dec 26, 2010 | 02:47 AM
BAD-GTO's Avatar
232/234 .595 .598
aka tqr2
Old Dec 26, 2010 | 01:21 PM
krissoto's Avatar
ms4 is a great cam, but not so great on huge shots, so def look into something different. call tsp
