Nitrous After Cam Install!
Old Jan 5, 2011 | 01:48 PM
19BLACKBIRD99's Avatar
Default Nitrous After Cam Install!
Im looking for a good kit, or an opinion of what size shot I should run with a car that has heads, and cam.
Old Jan 5, 2011 | 01:49 PM
Or if I should go wet, dry, direct port, or plate.
Old Jan 5, 2011 | 02:02 PM
ryarbrough's Avatar
Read the stickied threads at the top of the forum! They contain a ton of info on this sort of thing.
Old Jan 5, 2011 | 02:17 PM
ls1curt's Avatar
i'd go with a nitrous outlet or hsw wet plate system. what kind of power do you put out n/a? depending on your fuel system, you should be able to shoot 100-150hp
Old Jan 5, 2011 | 07:25 PM
EVL1SC's Avatar
^Agreed, both Nitrous Outlet and Harris Speed Works can get you headed in the right direction.
Old Jan 5, 2011 | 08:55 PM
Greekey's Avatar
I'd be sure to make sure you fuel system is capable of supporting nitrous on top of your head and cam. You should be looking into a fuel pump and injector upgrade.
Old Jan 6, 2011 | 04:40 PM
Chris@NitroDaves
Guest
Posts: n/a
If your not looking at going over 200hp then i'd suggest going with one of our plate systems. As stated above if you haven't upgraded the fuel system then thats the first thing that needs to be done.
