Need advice for 2 bottles w/ heaters?
It worked good but what i discovered is that even though i ran with both bottles completely open it would only empty the one that had the heater on it. so this year i've got a 2nd wrap style heater but i want to use it with the same pressure switch so they come on at the same time etc.
My question is, can i use the same pressure switch and will i have to add a 2nd relay? I'm not sure if the relay will handle that much draw from both heaters?
Thanks!
Can't you run a higher amp relay then splice the power/ground to the heater blankets? A pressure switch shouldn't have any problems connecting. Its just a switch.
Thanks!
nick
Couldn't agree more here.
My pressure switch is mounted immediately after the "Y" fitting in the main feed line, basically 1' max away from both valves. (i don't see any way to get it closer since i have to run dual blow down tubes as well)
Thanks a bunch guys!
