LT1 nitrous kit
Old Feb 10, 2004 | 09:08 PM
OneMeanZ's Avatar
Default LT1 nitrous kit
I have made the decision to go with nitrous. I've been reading a lot about nitrous and what I need to do, but I am far from knowing exactly what needs to happen. I know that I'll be getting either the TNT wet system or the NX wet system, running a 100 shot. Would a SPEC stage 1 clutch be okay? Do I know need to upgrade the fuel pump to a 255? or 190? I have a completely stock 1994 Z28, M6 with a Holley Ignition, Am I on the right track??? Thanks for the information..
- Shane
Old Feb 10, 2004 | 09:35 PM
Hambone 7's Avatar
you wouldnt need all that equipment to run just a 100 shot. not even the fuel pump if you are going with a wet kit.
Old Feb 10, 2004 | 09:45 PM
OneMeanZ's Avatar
Should I get NGK's TR6 though?
Old Feb 12, 2004 | 02:23 PM
Nitro Dave's Nitrous Outlet's Avatar
If you are spraying a wet shot.Order a NX kit and NGK TR6s.A window switch would also be a good ideal.And go for it.
Dave
