best spark plugs?
Old Jan 26, 2011 | 12:43 PM
bugy's Avatar
Question best spark plugs?
I'm using Edelbrock RPM Nitrous Plate System 70050. I'm gonna run with 150 HP. Which spark plugs would be the proper for this kit?
Old Jan 26, 2011 | 01:15 PM
Nitro Dave's Nitrous Outlet's Avatar
What kind of car? Whats done to it? What motor? Whats the compression? ETC. Need alot more info than what you have given.
Dave
Old Jan 26, 2011 | 01:34 PM
bugy's Avatar
this is a LQ9 6.0L LS1, 11:1 compression ratio, 243 casting heads, 110 octane fuel, 750 carb, manifold dual plane, pistons and crank stock, camshaft 236/242 duration , LS:113, MSD PN 6010, using MSD spark plug wires, perf headers.
this is a colorado chevy truck.
Old Jan 26, 2011 | 01:40 PM
I would put the NGK BR7EF plugs in it.
Dave
Old Jan 26, 2011 | 03:50 PM
bugy's Avatar
thank you
I was planning to use these NGK TR6, what do you think?
Old Jan 26, 2011 | 05:15 PM
Chris@NitroDaves
Guest
Posts: n/a
With the advances in plugs over the years the TR6 isn't the best choice anymore. The BR7EF will be the better choice of plug.
Old Jan 26, 2011 | 05:27 PM
bugy's Avatar
thank u very much
