window switch question
Old Feb 15, 2011 | 03:06 PM
lilmiller74's Avatar
Default window switch question
If I am running a window switch do I need a wot switch?
Old Feb 15, 2011 | 05:16 PM
Carter01's Avatar
Yes or it will spray every time you are within the set rpm range. Unless you get one of those deals where it utilizes the tps, in that case the voltage would act as the wot switch.
Old Feb 15, 2011 | 06:05 PM
Ok thank you
