Controllers
Old Feb 17, 2011 | 04:22 PM
fccs's Avatar
Default Controllers
I'm a little confused about controllers yet. Finishing up buying nitrous for summer but the main thing im waiting on is the controllers. I am going to have my tuner tune it so that when the system is armed it will pull X amount of timing and I want it setup so it can start spraying at WOT at X number of rpms up until X number before I shift. I was looking into the HSW controllers.. do I need BOTH the microedge & the interface controllers? Or do I just need one? I plan to set it and never touch it again basically.
Old Feb 17, 2011 | 10:16 PM
5.7mmImportkilla's Avatar
You can set then adjust then set then adjust again then set then You should be good.. microedge and interface one time set using the same jets..
Old Feb 18, 2011 | 05:44 AM
Cold06's Avatar
Or you can buy my interface and digital window switch and save money!!!
Old Feb 18, 2011 | 11:47 AM
Nick@HSW's Avatar
They don't need to be used together...the MicroEDGE is essentially a window switch with a bunch of built in features such as TPS, a/f shutdown, delays and a bunch of gear lock-outs. The Interface is a fueling and timing controller. If you have other means of fueling and timing then you don't need the controller.
Nick
Old Feb 18, 2011 | 12:01 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
I love the FJO controller, i have used a bunch of them, and this controller has always worked flawlessly.... easy to program through a laptop as well.... there is a reason its always on backorder lol
Old Feb 20, 2011 | 03:13 PM
wildbillSS's Avatar
Im running just the microedge and its working great for my setup. 150 shot 6 degrees of timing pulled when no2 activates. i use the microedge as a window switch and wot switch, but i spray thur the shifts with a built 4l60.
Old Feb 23, 2011 | 11:15 AM
fccs's Avatar
I'm a little confused. So why would I need the timing controller if I can have my tuner tune the car for when the nitrous is armed it pulls timing like yours with just the microedge? I would have a limit set to when it sprays but yea
