nitrous noob
Old Mar 8, 2011 | 07:38 AM
killerLSX275R's Avatar
Default nitrous noob
working on trying to figure out how to hook up a kit for a ls1 never hooked up nitrous but heres what i need some help with need to wire, bottle opener, msd timing twister, purge, wide open throttle switch and the nitrous solenoids themselves, wet kit dual nozzles mounted in the intake, no maf.
bottle opener im sure i can figure out looks simple
,im sure its all easy once i do it once or twice.
any advice is appreciated
Old Mar 8, 2011 | 09:03 AM
Graham@NitrousOutlet
Guest
Posts: n/a
The wiring sticky should have what your looking for. I am horrible with wiring as well.
Graham @ N20
Old Mar 8, 2011 | 09:24 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Graham @ N20
As Graham stated, a nitrous sticky would be a good place to start as there is tons of info that will be beneficial.
Or if you want a simple base diagram here is one a link that cover several different applications.
http://www.nitrousexpress.com/instructions.php
If you need any specific help there are several sponsors and very knowledgeable guys around here to help!
Do a little searching and then let us know if you need anything else!
Clay @NX
Old Mar 8, 2011 | 09:52 PM
alright thanks guys
