Stand alone question
Old Mar 11, 2011 | 09:42 PM
livnfast's Avatar
Default Stand alone question
I have a fogger setup for a carb engine I also have a stand alone fuel system for carb engine will it support my efi setup as far as working properly wanting to go for a 250 shot thanks for any info
Old Mar 11, 2011 | 09:55 PM
thedudeZ's Avatar
Yes to all. Setup the EFI as normal and use low pressure fuel jetting as alone with the standalone.
Old Mar 11, 2011 | 10:00 PM
livnfast's Avatar
Default Fogger
Thanks I was hoping so , And if you don't mind me asking why do alot of guys run so much fuel pressure on stand amines if they don't have too ?
Old Mar 11, 2011 | 10:11 PM
NXZ28's Avatar
The EFI Nitrous Kits rate the size of the shot/HP level using smaller fuel jets for high pressure EFI. This is because these kits are designed to be ran off the existing fuel rail of the vehicle. Some find it easier to just use the high pressure setting when they upgrade to the stand alone.
Old Mar 11, 2011 | 10:18 PM
livnfast's Avatar
Default Fogger
Thanks guys I just wanted to be safe on that because a fuel pump and noids are def cheaper than a motor thanks for the help and peace of mind
Old Mar 11, 2011 | 10:19 PM
thedudeZ's Avatar
I'm running a plate style kit with a low pressure standalone right at 6psi flowing and 60psi on the engine itself with efi.
Old Mar 11, 2011 | 10:24 PM
livnfast's Avatar
Default Fogger
That is music to my ears
