what time>>
Old Mar 14, 2011 | 08:13 PM
01c5targa's Avatar
Default what time>>
I recently sprayed my a4 2001 c5 corvette all stock with few bolt ons with a 75 wet shot..... on motor ran 12.6s on spray ran a 11.9 stepping up to a 100 shot what kind of times do a4s run with 100 wet shot? i tested it tonight an wow what a difference compared to a 75 was just curious how much et i will gain ...thanks
Old Mar 15, 2011 | 07:20 AM
dicky98z's Avatar
nice gains on the 75 shot, im going guess you will pick up another 2 tenths or so.
good luck
dicky
Old Mar 15, 2011 | 12:13 PM
KONG's Avatar
Well if you hook the car should run 11.50-.60 range. 100 pill usually lowers your basline about a second or so. Make sure you put some good plugs in it and pull some timing out (Just to be safe). 2 degrees should work with that small of a hit.
Old Mar 15, 2011 | 12:19 PM
KONG's Avatar
BR7EF NGK Plugs gapped .35. One heat range colder than you are currently running.
Old Mar 15, 2011 | 03:10 PM
1lejohn's Avatar
My best on a stock motor was 11.4's on a 150 shot. LS1 ,a4 ,3:42's.
Old Mar 15, 2011 | 06:08 PM
01c5targa's Avatar
thanks guys...
