Pull timing witout cos5 on pin 53.
Old Mar 20, 2011 | 07:40 PM
green96ta's Avatar
Default Pull timing witout cos5 on pin 53.
Ok, I have talked to a tuner and I thought I should pass this info on. Red pin 53 is the timing retard request pin for the tcs or asr. Well if you dont have tcs or asr you can change that table to pull the proper amount of timing and you have the same function as pin 56 using the pcm.
