it's time for nitrous". couple ?
Old Mar 25, 2011 | 12:06 AM
1hotlt1's Avatar
Default it's time for nitrous". couple ?
i just install my nitrous on a lt1 but i have couple of questions...... Can a stock timin chaing andle 100 to 125 shot of nitrous or even 150? am pushing 350 rwhp all motor now. Thanks guys.
Old Mar 25, 2011 | 09:47 AM
dnkynrbk's Avatar
I would contact NitrousOutlet. There are a few guys that work there that run LT1s they would be glad to help you with your questions and set up
Old Mar 25, 2011 | 10:32 AM
skeeter99's Avatar
I had a m6 lt1 back in the day with comp 306 cam and bolt ons with 125 shot i had a fresh motor with new timing chain thats something u normally replace on a cam swap because of the new rpms ur spinning I would assume u have a cam now with 350 hp on a lt1 so u may already have a new timing chain something like that can never hurt to install Is it needed probally nor depending on ur miles and abuse u give it u may wanna replace it its not already been done on the cam swap
Old Mar 25, 2011 | 12:51 PM
1hotlt1's Avatar
You are correct they change the chain, but I guess the maching shop put a stock
Chain! It's new thou! Block has around 8,xxx miles.
Old Mar 25, 2011 | 01:01 PM
Tony Shepherd's Avatar
Stock chain will handle it fine for a while. It will eventually stretch. An upgrade should be in your future.
Old Mar 25, 2011 | 01:43 PM
skeeter99's Avatar
Just as Tony said ur good for now so go have fun!!!!
