Ngk br7es
Old Apr 25, 2011 | 12:40 AM
hotrodsgmoney's Avatar
Default which nkg letters tell a little story about this plug.
Originally Posted by Mereniuk
Are these plugs ok for a bolt-on LS1 for a 150 shot?
A local place had these in stock, so I thought I'd ask before I put them in.
Thanks in advance!
when using nitrous,only short probe NON PLATIUM plugs fit the bill
Old Apr 25, 2011 | 05:17 AM
Thanks in advance!
Are these the long or short probe?(ground strap)
Old Apr 25, 2011 | 10:49 AM
Graham@NitrousOutlet
Guest
Posts: n/a
You have recommend that people run " short probe " in 2 threads and asked which ones to run in 3 I think.
You want to run a non-projected tip plug with nitrous. Period.
Heat range will depend on the combination and amount of nitrous being used.
BR - Is the NGK prefix for non-projected V-Power plugs.
Br7ef
br8efs
br9efs
All these are non-projected V-Power plugs with corresponding heat range.
Old Apr 25, 2011 | 12:17 PM
camscam02's Avatar
br8es
br9es
Just so no one gets confused, the 2 plugs above will not work on the ls motors. Needs to be:
b8efs stock # 1049
b9efs stock # 1085
Old Apr 25, 2011 | 12:33 PM
Guest
Posts: n/a
b8efs stock # 1049
b9efs stock # 1085
Good catch Cam.
Old Apr 25, 2011 | 01:02 PM
camscam02's Avatar
Good catch Cam.
No problem! Thats what I'm here for.
Old Apr 25, 2011 | 09:01 PM
ClubPlug.net's Avatar
Hi Folks
This might help.
BR7EF V-Power Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Solid Terminal Nut, V-Power (V-Grooved Center Electrode), .028" (0.7mm) Gap, Heat Range 7
B8EFS Traditional Spark Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Non-Resistor, Removable Terminal Nut, .028" (0.7mm) Gap, Heat Range 8
B9EFS Traditional Spark Plug, 14mm Thread Size, 17.55mm (.691") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Non-Resistor, Removable Terminal Nut, .028" (0.7mm) Gap, Heat Range 9
Also, in terms of wire set, you can use the NGK-RC-GMX090 (51054) performance (blue wires) for the CHEVROLET CAMARO SS / V8 / 5.7
In terms of NGK symbol description you can visiting the Official NGK site at:
http://www.ngksparkplugs.ca/documents/partnumberkey.pdf
