DEI NYTREX nitrous kit? Any input?
Old Mar 30, 2011 | 08:22 AM
dville_gt's Avatar
Default DEI NYTREX nitrous kit? Any input?
I have a deal lined up for the following parts for $350, this is not the TripleThreat setup where all the solenoids are combined, he said this kit uses separate solenoids, any input? Good deal?
1 NYTREX EFI wet kit
10lb(filled) powder coated black bottle with brackets
Remote bottle opener
Bottle heater
Bottle pressure gauge
Purge solenoid
Qty:2 main feed lines
3ft 4an fuel line
3ft 4an nos line
and some misc fittings
Brand new still in box stuff
Msd window switch
3 sets of pills from 3k-5.9k
extra full throttle switch
extra 3ft 4an nos line
4an y fitting
rubber fuel line
aluminum hard lines for nos & fuel
nos purge switch
nos master power switch
Old Mar 30, 2011 | 09:14 AM
1lejohn's Avatar
Does it come with the fuel and N2o noids? Yes its a good deal. I would check the operation of the noids before installing and running the system.
Old Mar 30, 2011 | 09:43 AM
dville_gt's Avatar
Yes, comes with the noids. Only thing I am unsure of is the nozzle, I just asked him about it. He claims the noids work perfect, but as far as checking the operation, do you just mean putting +12v to them and seeing if they operate or do you mean actually disassembling the noid it self?
Also, is the NYTREX stuff decent?
Old Mar 30, 2011 | 09:58 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
That seems like a good price if it is all in good condition. If it looks like the solenoids are fairly old, I would go through them and have them serviced. If you feel comfortable enough doing it yourself, then there is a thread you can search for that has tons of helpful info. If not there is several knowledgeable people around that can.
Clay @NX
Old Mar 31, 2011 | 08:32 AM
1lejohn's Avatar
I would put pressure on them and then apply 12volts and see if they actually open and close and stop the flow. I have some noids that are 12yrs old that still work great.
