nitrous kits
Old Apr 1, 2011 | 11:30 PM
+badss+'s Avatar
Default nitrous kits
i have a stock 2002 camaro ss that i wanna hit with a 150 wet shot whats a good kit to get dont need anything super crazy lol im gunna run a 150 shot til i get motor and procharger setup next year wanna keep it as safe as possible and what do i need to upgrade fuel wise was thin king of going dual in tank pump can i do that or do i need a secondary set up for only when on the bottle?
thanks to anyone who can help point me in the right direction
Old Apr 2, 2011 | 12:07 AM
LilJayV10's Avatar
Are you talking about a fuel system for nitrous or the procharger setup?
If you are talking about just nitrous most people, myself included, run the racetronix pump with their hot wire kit. It's simple and reliable.
As far as who has the best kit, IMO, they all are similar. HSW, Nitrous Outlet, NX are all great companies with good tech support. I have HSW stuff. I ended buying a new kit from a board member for a good price and I have stuck with them. I know a lot of guys mix and match parts but I don't have enough knowledge to do that.
I think Nitrous Outlet's wet plate kits are cleaner looking. That's my main complaint about the HSW kit. I will be getting shorter lines soon to clean the engine bay up.
In short, you can't go wrong with any of the nitrous sponsors on this board.
Old Apr 2, 2011 | 01:33 AM
Cold Zero's Avatar
If you are not using nitrous as your " Power Adder " and planning for different setup shortly ( like what you stated about motor and procharger ) then go with
- Nitrous Outlet Dual Nozzle Kit : http://nitrousoutlet.com/catalog/pro...9&product=2529
- Upgrade your stock fuel pump to Walbro 255
- Use NGK BR7EF Spark Plugs ..
- and rock n' roll
Old Apr 2, 2011 | 09:41 AM
+badss+'s Avatar
ok so if i go with racetronix twin in take pumps im good then right. that should me good for both while i run n2o and then later when i switch to FI.
Old Apr 2, 2011 | 09:57 AM
1998flamedCamaro's Avatar
You will NOT need twin pumps for a 150 shot. A single racetronix will be fine with room to spare.
