What kit should i get
Old Apr 13, 2011 | 03:33 PM
therobman's Avatar
Default What kit should i get
looking for a dry kit for my 2000 t/a its a cam only m6 car with 415rwhp. Im new into the nitrous game so i looking for a simple kit thats easy to use and install. What type of kit and brand wise would you guys recommend. i was looking at hsw kit and nitrous outlets
Old Apr 13, 2011 | 03:42 PM
ls1curt's Avatar
nitrous outlet makes a very nice kit. why not go wet?
Old Apr 13, 2011 | 04:07 PM
therobman's Avatar
was looking for a easier install i guess most dry kits im looking at are mostly plug and play. Only looking for 100 hit from time to time nothing crazy but want a safe kit
Old Apr 13, 2011 | 04:49 PM
Chris@NitroDaves
Guest
Posts: n/a
First off with you wanting to spray the car with a dry hit you care going to have to upgrade the fuel pump [ if you still have the stock one in there ] in the car even to spray a 50hp shot. Also with the dry setup you will need to know what your injector duty cycle is because you might have to upgrade those as well to suppor the nitrous.
Also just for thought the dry kit is only easier to install by 2 wires. Other than that they install the same.
Here is a good read on Dry vs Wet
http://www.nitroustech.com/forums/showthread.php?t=92
Also if you'd like too give me a shout here at the shop and i'd be more than happy to go over any concerns or questions you have.
Old Apr 13, 2011 | 09:32 PM
99 Blue Bird's Avatar
Good read but still does not help me pick between dry or wet lol. to many options in setups to pick lol.
op i was thinking about N2O outlets Halo system. check it out. might be what you are looking for. but it seems to be cheaper to just run a wet plate setup in the long run.
Old Apr 14, 2011 | 05:43 AM
ta-stanger's Avatar
I went with Nitrous outlet plate sytem and did a 100 shot! Very easy and easy to tune. It has so many safty features blowing up anything is damn near impossible. Plus the plate system is really clean and looks good in the engine bay. With the instructions they send you can hook it up witout any trouble! Good luck and get ready to really in joy the extra 100HP
