Mind checkin a quick datalog?
Old Apr 15, 2011 | 08:26 PM
thedudeZ's Avatar
Default Mind checkin a quick datalog?
Couldn't make it to a track so figured I'd make a quick hit. Datalog and tune down below.
stock 28lb injectors
ls6 intake
tsp 5.3 stg 2.5 heads
230/232 114 f13 cam
th400
9in 4.11s
850psi bottle pressure
I had the timing set to 20* at WOT but for some reason it went to 25-27* at WOT.
this was on a tnt dual nozzle kit. 39nx2 35fx2 6psi flowing 110 from standalone.
No where to really be able to pull over and check plugs around here just wondered what the deal was with the timing not dropping down accordingly.
Will be getting a wideband on the car for a constant point of reference for major changes in between plug checking. Plugs BR7EF's.
Any input is greatly appreciated.
File Type: hpl
File Type: hpt
