custom switchplates
Old Apr 19, 2011 | 05:34 PM
High_Angle's Avatar
Default custom switchplates
Does anyone make a switchplate where the actual firing of the nitrous is done by holding down a button?
my last car has a toggle switch to arm, purge, heat and a button i held down to spray
the first ten seconds are what im talking about......i held down the bottom button to spray and let go to stop.
http://youtu.be/ioihb1V8pqk
Old Apr 19, 2011 | 07:34 PM
krissoto's Avatar
you can wire it up how you want it, just gotta break the power or ground wire, alot of people do a wot switch, but if you want it on a button on the shifter, or steering wheel, you just gotta wire it in.
Old Apr 19, 2011 | 10:45 PM
got-a-ls1's Avatar
easily done.... Just install a momentary pushbutton in line with the relay trigger circuit.. really doesnt matter what side of the relay you interupt. only question is why.. just use a window switch if you do this... as i see no benefit of it. Inconsistent for track use and unsafe without a window switch and wot switch. If just for on the street seems kinda fast n furiouzzz but thats just my opinion too much going on during a run.
Old Apr 19, 2011 | 11:05 PM
Iroc-z_23's Avatar
X2. You don't want to be spraying and accidentally get out of the throttle. Just don't be a Paul walker!
Old Apr 20, 2011 | 08:02 PM
High_Angle's Avatar
me holding the button and depressing is the window switch. the car in the video, i consistently sprayed in 1st gear at 3000 and let off at the end of the race.
worked fine for me. i was hoping to find some pics of other ppl who have this in their f bodies
Old Apr 21, 2011 | 08:54 AM
Graham@NitrousOutlet
Guest
Posts: n/a
It is no where near as safe to do this. If you want to run a button you still need some sort of WOT activation and a window switch is still Highly recommended.
There are more than one setup where having a button can be very useful.
Old Apr 21, 2011 | 05:52 PM
High_Angle's Avatar
in the video, the first button i flip is the arming (esentially the WOT).
so what im getting is there arent any switchplates for fbodies like im describing?
Old Apr 22, 2011 | 07:55 AM
Beer99C5's Avatar
Kinda what makes the Custom...
Here is one I did for a Vette, its da Go Baby Go button...
F-Body would be similiar (different shape obviously).
Seems to me, a Momentary trigger switch would be better suited on the Steering wheel or shifter so your not leaning down looking away from the road though...Summit Racing has some of these switches.
A panel with the Arm Heater Purge is easy to do, the remote trigger switch would be separate from that though...
Old Apr 22, 2011 | 11:19 AM
Nitro Dave's Nitrous Outlet's Avatar
Beer, That looks good.
Old Apr 22, 2011 | 11:26 AM
Ravenous T\A's Avatar
Having both hands on the steering wheel as much as possible during a race is always a good thing.
Old May 3, 2011 | 10:46 PM
fastsspr's Avatar
I'm another one who thing that what you want to do is not safe at all. For your engine and for your life.
Old Jun 4, 2011 | 10:30 PM
Rubrburnr's Avatar
How think is the plastic you guys are using for your panels?
