nitrous controllers that offer timing controls?
Just use whatever window switch you want and then install the "resistor mod" to trick the IAT sensor to think the IAT is hotter and I beleive for a Camaro the PCM will pull 3 degrees by default. You can edit those cells in your tune with HPTuners to pull more. At least you can in a C5 Corvette. I pull 9 degree using the "resistor mod" when nitrous sprays.
Sarge
Just saw you are in Louisville too. PM me.
The only problem is getting them. They are currently on a backorder as well.
